airspace?
yeah your looking at about 13 1/2 cf net. what is the dimension for the top though so i can figure it out exactly? mine is 40" wide, you could go probably 42-44"max if you had to. were you the one asking about building a wall on S10forum too? for 4 15" SE's? my wall is only 15.25" deep on the bottom, 13.75" deep top, i only have a 1.5" lip on the back, thats really all you need. since your doing 1" mdf, it would be easy to do a 2" lip for you. you wont need a 4"
hope you plan to lose some leg room //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif... should be LOUD tho.
yeah im the same one i like to get all the opinions i can.
the top is 42" and i wasnt really sure on the lip, i just figured i would go with 4 to be sure, but if a 2 inch will work ill do that instead. more airspace.
and the leg room isnt a problem im a skinny f***** and i dont like a gangster lean when im driving a std, its easier for me to drive.
i just refigured it up with only a 2 inch lip instead of a 4 and i got less airspace instead of more...... i got 13.826 cft this time anyone want to double check this?
bvr_j_0969
bvr_j_0969
kentucky
bvr_j_0969
