i got a 2000 2 dr blazer with a 3/4 drop on it now. If I were to do a bag setup myself, how much would all the parts cost total(rough estimate). Is it a possible DIY?
Between $2,000 and $2,500 bucks depending on if you have drop spindles and what tools you have, welders, hand tools, acetylene torches, cutoff wheel, air comp, bench grinder, sawsall, drills, metal bits, metal hole saws, drill press, etc..... And that would be to lay frame, I would recommend doing a stock floor body drop as well, blazers need the rockers on the ground to look real good, so I would build a new frame from the firewall back. But thats just me!!!!! Theres a plethora of issues youll run into when bagging a truck, wheel tubs, rasing the gas tank, suspension geometry, hype-x ball joints if needed, relocating battery, inner front and rear wheel tubs, rasing ecu and harness, (on most gm vehicles), gauges (I recommend digitals, needles arent as nice and you cant have any real precision with them or safety settings like you can with digital. If you do it, if theres a will theres a way, i'll help you through it. And yes its a DIY but you have to be patient commited, and have $$$$$$ especially if you have to buy tools, it takes alot of money to completely destroy what engineers took years to prefect!!!!!lol.
