ahhhhhh helllpp
SlammeD_SiR
im installin my system right now as we speakkk, and the amp im using i think is *@#*ddddd uppp
soo im gonna try wit my other amp and i neeed to kno how to bridge the channels.
and also its the eclipse 6213
it has no 2 ohm bridged rating, does that mean it will pop if i try to go to that loadd???
its the only load i can do at the moment cuz the box, i dun have the terminals to wire each vc
PLEASE HELP
Very few amps are stable to 2 ohms bridged...they're out there, just not extremely common. 4 ohms is far more likely.
Usual procedure to bridge the channels is connect a positive of one and the negative of the other...should have a little marking near the speaker terminals.
it has the possiblity of burning out your amp.
Your amp may just go into protect until you put the correct load on it.
it is a gamble //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif unless you can find someone that ahs tried it before and was successful.
I think we've all done the 'paperclip fuse' trick at one point or another, just to get the blasted thing to work...problem is, the result tends to be something catching on fire //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
To the original poster, if it's not stable down that low, it won't do it short of modification. And that may or may not be successful. So just wait until your enclosure is finished.
SlammeD_SiR
SlammeD_SiR
Toronto, CAN
SlammeD_SiR
