AGU fuses??
Is this fused at the battery or amp? On my brothers US Amp there's more than one + terminal and you can run one than one power wire to it from the fused distro and use agu fuses. I'm guessing this would be fine to do with other amps aswell.
thx for the links.
does anyone have a wire chart? or is 250 amp fuse the norm for 0/1 guage wire at the battery??
also, JL says when splitting the wire, 50 amps should be used PER amp . you think 80amps are okay? i havent seen many 50amp ANL fuses around. i have a ANL distro block.
what about this part?
your fusing the power wire to protect it from burning the car to the ground the amps should have fuses to protect themselves.
so i leave the distro block empty with no fuses? is that even possible?
i will be fusing the 0/1 guage at the battery, but with 2 amps i gotta split the 0/1 in the trunk in my distro. so i assumed i need 2 more fuses to go in the block of 50amps, coz thats what JL says????
anyone?
95Prober
95Prober
Canada
95Prober
