Aeroports vs. Slot Ports
i've used 3" and 4" pvc with success. i like to use 2 4 inch ports, but you have to design your box carefully to be able to fit 20 inch long ports in the box. a single port is much shorter to get the same tuning.
you can bend a slot port, it's not advised to bend an aero because when you bend, theoretically it may introduce more turbulence. Aeroports are supposed to be used to rid as much turbulence as possible so it'd be a waste of design to bend aeros...
You can bend slot as i said before, just measure down the center of the port when calculating port length.
Whatever the total length needs to be, subtract 0.75" of that length if using 0.75" MDF as the thickness of the wall counts as port length unless you are running the port wall straight out the box and making it flush with the outside wall...
Anyways, whatever the internal width is of your port, divide that number by 2 then subtract this number from required port length and that's the actual physical port length you need to make. remember, just measure down the center to get your length. Keep turning the port 90 degrees until you get the right length.
Remember - if you are trying to achieve a certain tuning-
Increasing port area will only increase port length requirement.
Decreasing port area decreases port length requirement but may cause port noise. Try to stay within 12-16sqin of port for every 1cuft NET of volume internal.
Increasing internal volume decreases port length requirement.
Keep this in mind when trying your best to determine how you want your port to be made.
That 12-16in² per cubic foot of volume isnt a rule of thumb by any means, hell tons of my designs have 22in² per cube and slam hard as ****. Every sub is different, use winISD and make the enclosure properly instead of the newbie 12-16in² 'rule'
17yr old thread but forget that, can you help me design something that'll slam "hard as ****?"
Aww... I was trollin' for expertise, it sounds like Op has a chip on that ego and I was askin' for help. You can't know it all so I was ready to pull him into the rabbit hole on enclosures. Winisd is a learning experience all by itself. I'm a testing guy who learned Winisd. "Slammin' hard asf?"
I was trolling man...
155ish on 2 15's? I'd like Op's expertise.
I can't believe how far you've come. :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
We all learn and some take task to hand. Being hangry /w/ a maths background while being a basshead certainly helps. I went myself from a poser on the SMD forum to 2yr as top of the garbage heap in my org. Every designer reverts to their best result and being asked things like asking to dig up Hornsrep knowledge for palmares kidna sux tbh. Winisd can be a help but after decades of testing and modeling some things either work or they don't as a designer 22in2^ft3 of port must be for those new unicorn 10K rms, 80mm xmax team subs :ROFLMAO:
I've had to maybe allow for 18in^ft3 of port for smaller capable drivers but nothing I would classify "slammin' hard asf"... haha
17yr old thread here, where is the guy who responded recently? I did quote him to illicit a response
Buck
little alien on campus
Buck
Inside of a pyramid
shredder1
