Adire Koda8 T/S data
Errr, that PDF doesn't have all the parameters I need.......//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
What else do you need?
Here's what BassBox calcs out for the rest of the parameters:
Fs = 32 Hz
Qms = 6.5
Vas = 36 liters
Cms = 0.71 mm/N
Mms = 34.84 g
Rms = 1.078 kg/s
Xmax = 12 mm
Xmech = 18 mm
P-Dia = 155.1 mm
Sd = 189 sq.cm
P-Vd = 0.000227 cu.m
Qes = 0.42
Re = 3.4 ohms
Le = 1.1 mH
Z = 4 ohms
BL = 7.53 Tm
Pe = 150 watts
Qts = 0.395
no = 0.271 %
1-W SPL = 86.47 dB
2.83-V SPL = 90.19 dB
JonJT
JonJT
Jersey
JonJT
Mike Mccabe
