Adire Koda 12" Vs AA Arsenal 10" (yea another one)
Justintoxicated
Final elimination...
Simple Question.
Which should I get?
The Koda is more money, but the Arsenal would require a new amp..
Existing amp is 600x1 @ 4 ohms, so if I wired the Koda D4 to 8 ohms the amp should put out 300 watts correct?
I'm comparing the 10" to 12" becaause I can fit a koda 12" or Arsenal 10" but I can't fit the Arsenal 12" due to mounting depth restrictions.
The koda 12" has 5.5 inches of mounting depth
Xmax of 18mm
300 watts RMS
Arsenal has
Xmax of 20mm
750 watts RMS
400 watts Rec?
Box should be around .75 cuft
BTW, neither of these subs is going to be reviewed in the shootout so I figured I may as well ask now. I'm looking to send out money tomarrow!
//content.invisioncic.com/y282845/emoticons/read.gif.ff512c499c00ed3faae9a20f4b088b29.gif Type R is no where near able to fit in the box and I would not run one even if I could. Please I have narrowed my search to these 2 woofers and would like to purchase one today...
If the Arsenal + Amp would be less than the Koda, I would go that route. But if it wold be more, I'd just get the Koda. I loved the old Koda's.
Neil
I was messin with you //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I have no other input //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Thanks PunkORama, I called Asscendant audio and they were sold out on the Arsenal //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif They said they could not give me an exact date on when they would be getting more either.
So I picked up an Assassin instead //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif only $89 shipped FTW (they old had 2 left, now they only have 1! ). The koda might be in slightly too small of a box and the 10" kodas are not out yet. If I'm not happy with the Assassin I can try to get a 10" koda in the future or maybe the Arsenal (depending on if I can even fit this assasin), I might have to glass a bitfor downfire... for $89 I coulden't pass it up!
I plan to run it off my exisitng amp since it is 4 ohms, and maybe feed it up to 500 watts since the box will be so small...
Justintoxicated
Justintoxicated
San Diego, CA
hoaxci5
