Sold Adire, Alpine, Audiocontrol, Wiring
mustatang
IL
$150 each - (2) Alpine 3544's (mint)l
$280 - Koda 6.1 Component Set Mark 2 (brand new)
$220 - 10" Brahma Mk 1 (NOS - chipped plastic bottom only cosmetic)
$125 - EQX (2 very minor scratches, looks new) and 15’ P,G, and RTO
$75 30’+ 1/0 w/terminals, 10’+ 8 w/terminals, 1 Stinger distroblock – (2) 1/0 ins and (3) 4g outs, 1 Stinger fuse holder w/ 150A fuse.
The Alpine's are old school (vintage) SQ amps and are the little brother amps to the 3545 used in the Richard Clark Soundworks Vehicle. These are in almost mint condition and for their age it is remarkable how good they look. Made rock solid in Japan before the move to Korea.
The Alpine's specs are 150w x 2 @ 12.5v (4ohm) and then 400 x 1 @ 12.5v (4ohm). However these old school alpines are severely underrated and bridged with the car on you can expect in excess of 600w easily.
It is a new old stock item. It is a Mark I so it has the 4 spoke basket. Concerning the one I have versus the MKII. The MKI I have is from the very last batch of MKI's so it has the same terminals, cone, topplate, and spider as the MKII unlike some of the MKI's. The main difference is there is no slant on the bottom of the pole piece and the basket. Everything else is the same. Put in a box you would never know the difference. The Brahma has seen power once (200w) for a test. It has a few minor scuffs and a nick on the plastic bottom, but nothing that will matter if it is inside the box or effects performance. 10" Brahma in a 1 cube box tuned to 28hz the 600w from the Alpine is perfect for it. http://www.adireaudio.com/TextPages...geFrameText.htm
The EQX allows for you to have 13 bands of EQ and an active crossover between the sub and component set. I have crossover modules for 70hz and 80hz. It also has a built in subsonic filter I have modules for 33hz and 20hz so you can protect the ported sub. http://www.audiocontrol.com/MobileA...lizers/EQX.html
The EQX will take balanced RCA in, normal RCA in and even hi level input for aftermarket of stock HU’s. It also has a clipping meter to tell you when you have maxed the input and ouput. Has all the plugs.
I have references at SIN with perfect trader rating.
Contact me via btforums @ yahoo.com or PM.
Thanks for looking.
where @ in IL?
Wheaton, IL 60187 about 30 minutes due west of Chicago in DuPage County.
You want something and want to pick-up or meet half way to avoid shipping? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Update:
*** $280 - Koda 6.1 Component Set Mk 2
-SOLD
*** $130 each - (2) Alpine 3544
2 x 30A (fuse)
Underrated expect 600w+.
Made in Japan.
*** $200 – Adire Audio 10" Brahma Mk I
It is a new old stock item. Tested. It has a few minor scuffs and a nick on the plastic bottom, but nothing that will matter if it is inside the box or effects performance.
*** $110 – Audiocontrol EQX – Series II
- 6.5 ft Power, Ground, and Remote
- 70hz, 80hz crossover and 33hz, 20hz subsonic
The EQX allows for you to have 13 bands of EQ and an active crossover between the sub and component set combined with a subsonic filter. http://www.audiocontrol.com/MobileAudio/Products/Equalizers/EQX.html
*** $75 Wiring
(2) 1/0 gauge – 16 ft.
8 gauge – 10 ft. - Directed Audio
8 gauge – Terminals
Distribution block – S2064IE – Stinger (2) 1/0 input and (3) 4g out.
Fuse Holder – SEANLFH - Stinger
Fuse – GANL150 – Stinger
Contact me if you would like any of the wiring individually.
Thanks for looking. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
WTF?!?!?!?!?!
Trader.
I'm in Elgin this week. Call me.
Back in chi-town...Elgin! Awesome. I'm not a trader. We'll talk. You'll see. //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
mustatang
mustatang
IL
cyantist
