adio is succeed
Unless you're in IASCA //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
The idea is that you're not as reliant on a crimped connection (actually two, with a butt) with a properly soldered splice, and heatshrinking it provides a better measure of insulation than if the butt connector becomes loose.
But I like those insulated barrier strips I linked to earlier...much easier to change things in the future, and still very secure.
But really, anything would have been better than packing tape and dreams.
yeah, like functionality, which i acheived, young jimmy
Well I am not in it, so I guess I am ok then. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Also I have never once had a butt connector come lose.
heat. I will get out the kitchen.
adhesive fail God dammit, I am tired of this deadening debate!
tape loosens Here we go again.....
wires touch Is that like when your penis touches your boyfriend?
HU smokes. Cool effect!
bad habit You have way to many of them
lung cancer Sorry mang, how long they give ya?
dies.How is the speed on the netz down there?
Huh!
butt connectors are OK, but I prefer not to use them under dash. When re-installing a radio, a butt connector that has a bad crimp can malfunction and you will not know it until you have the job all zipped up and THEN you realize you have lost a connection (that sucks) In addition, wires are sometimes not tight in a butt connector. n00bs often dont have the proper tools for a good crimp. By not having a good crimp, the wires arent secure in the connector, they can arc and short, heat up and eventually fail or worse cause fire. Solder rarely fails (if done correctly and not cold soldered). Id ALMOST agree that twisting a wire together is superior to butt connecting it if not for the strength of a PROPER butt connecting joint.
As far as the tape thing goes.. Electrical tape is infinitely flexible, and more heat and water resistant than package tape and will take prolly 1,000 times more abuse. Therefore a better insulator //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif The last place in your car you want a short or arcing condition is under the dash. By the time you realize its bad, its often too late and the fire department is en route to put out your car-b-que.
butt connectors are OK, but I prefer not to use them under dash. When re-installing a radio, a butt connector that has a bad crimp can malfunction and you will not know it until you have the job all zipped up and THEN you realize you have lost a connection (that sucks) In addition, wires are sometimes not tight in a butt connector. n00bs often dont have the proper tools for a good crimp. By not having a good crimp, the wires arent secure in the connector, they can arc and short, heat up and eventually fail or worse cause fire. Solder rarely fails (if done correctly and not cold soldered). Id ALMOST agree that twisting a wire together is superior to butt connecting it if not for the strength of a PROPER butt connecting joint. As far as the tape thing goes.. Electrical tape is infinitely flexible, and more heat and water resistant than package tape and will take prolly 1,000 times more abuse. Therefore a better insulator //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif The last place in your car you want a short or arcing condition is under the dash. By the time you realize its bad, its often too late and the fire department is en route to put out your car-b-que.
well, i twisted the wires together. i had no idea and still don't know what a butt connector is.
oh shit:laugh:
not my pic but the yellow things are butt connectors, and the blue things are scotch locks (about the sh!ttiest connection available)
Good job black man, now theres another car ****ed up buy a ghetto nga install. I wanna be proud of you for attempting and completing the job, but another part of me is mad because youre black and do what all blacks do. Sad //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Keep in mind though, the only difference between your install and a white mans install, is that us whites dont use packing tape. Other than that, GJ.
adio
THE STEREOTYPE FIGHTER!!!
adio
college park, ga
James Bang
