Adhesive
Some type of spray adhesive from a fabric store, all I remember is that it wasn't 3m and it cost like $8. It was a couple years ago.
I'll use s.a again, just wanted to see if there was a better/stronger option out there for about the same price.
If you used 3M it should be some what ok. You can hit up home depot and they will have a few options from 3M that you can use. If your carpet is coming up along the edges only, you can use a hot glue gun to fix it.
It's iffy throughout the panel but worse on the edges. I'd be better off just redoing the whole thing. Guess i'll try and do a better job this time, Thank's guys.
3M is what I use for spray in a can. I prefer DAP Weldwood contact cement as I use that more. depending on the material if the fabric is going behind the panel like a beauty panel, i put a few 1/2" staples.
Sleeklsc
Sleeklsc
jirehn
