chuksw9ve
Ok,what is considered the peak frequincies of a song,the loudest parts?The parts that are held the longest?Could somebody tell me?
Your question doesn't really make much sense. Do you want to know what the highest average frequency in music is? Or do you want to know about transient peaks in amplitude?Ok,what is considered the peak frequincies of a song,the loudest parts?The parts that are held the longest?Could somebody tell me?
Good, you're not as cluess as you sounded. When somebody says there are peaks at x frequencies means that those are the notes of the bass line used. Typical bass range is from about 80hz to 1hz with ~25hz and down considered subsonic bass. It's basically saying, "this song is played with this chord progression: Csus, G, Dsus, E." Only they use frequencies to describe the note used. The "peaks" term is used because usually songs contain notes that range from 33-36 with a maximum around 34.I'm guessing that its the number of wave crests and valleys in a given measurment.Less waves means lower tones and vice versa with higher,I know 440hz is and A in standard music tuning...I guessing 220 would be an octave lower,and in what is considered the "bass" range.Does that sound right?I'm thinking whats measured are the notes in the bass range only,but what determines a songs freq when a song can have many notes within that range?
