Ab 120.1?????
i owned one. although i had a longgg issue with an rca problem getting repaired through AB...it was a good little amp that put out power. can run at .5 ohm all day.
what kind of power? and what comparison would this have against the sundown 1500d or IA 20.1
Very good amps, I have sold around 15 now. Not a single problem at all //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif! If you notice on AB's page the fuse rateing is off //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif Both of the 120.1's in my blazer are clamping at around 200A of current draw each when running them:laugh:. You do need a beefed up electrical system to keep them happy. I am powering 2 Re audio MT 18's ( a 120.1 on each) and they will give the mt's a work out:veryhapp:.
Very good amps, I have sold around 15 now. Not a single problem at all //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif! If you notice on AB's page the fuse rateing is off //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif Both of the 120.1's in my blazer are clamping at around 200A of current draw each when running them:laugh:. You do need a beefed up electrical system to keep them happy. I am powering 2 Re audio MT 18's ( a 120.1 on each) and them will give the mt's a work out:veryhapp:.
what kind of power were you clamping and at what voltage?
The current draw was off of a tsunami hybrid 40 farad cap, so it may not be totally accurate:D I did test each amp with a 1ohm load ( my mt's:)) and the amp did 51.75volts on a 40hz tone, so around 2678rms:)
jaredspl
jaredspl
local liquor store
jaredspl
