a techincal question about amps
Here's the formula.
http://en.wikipedia.org/wiki/Damping_factor
Some argue that a DF of 10 is good enough to drive a speaker well. Marketing
people will tell you that DF should be thousands, millions or billions, lol.
A good solid state amplifier will have at least DF = 100.
Some tube amps can have low DF.
From wiki "Nelson Pass made a case to be for a loudspeaker system with zero electrical damping."
lol ..
Here's the formula.http://en.wikipedia.org/wiki/Damping_factor
so in the case of a d-class mono amp, is this spec decent: Damping Factor > 700
I actually just went partially over this in another thread;
http://www.caraudio.com/forum/showpost.php?p=2808283&postcount=92
You want the damping factor to be above a certain value. But going beyond that yields nothing beneficial. DF isn't a spec where higher is always better. Just as with slew rate, there comes a point in which going any higher doesn't yield any audible difference. This point is typically considered to be 20. So if the amp has a DF of >20, then it has adequate damping and there will be no audible effects.
Really, the only time damping factor would be a remote consideration is for a tube amplifier, which have very high (comparatively) output impedance. Most any solid state amp will have more than adequate enough damping.
95Prober
95Prober
Canada
squeak9798
