1) MTX JH300
RMS Power Output (Watts x Channels)200 x 1 @ 4 ohms
Peak Power Output (Watts x Channels)300 x 1 @ 2 ohms
Width (inches)9-5/16Height (inches)2-3/8Depth (inches)12-1/8
$70 Shipped
2) MB Quart PWD160 6.5" mids, from the QM160 comp set, Made in Germany
These are some great mids. These have some marks on the mounting holes, and very, very light scratches on the cone. Does not affect performance whatsoever. They are consecutive serial numbers if that matters.
$70 Shipped
3) MB Quart PTK40 Widesphere Tweeters (Off-axis MONSTERS!)
* Sensitivity: 93 dB
* RMS Power Range : 50 Watts
* Peak Power Handling: 100 Watts
* Frequency response: 3000-32000 Hz
* Diameter: 1.6 Inch
* 6 Ohm
Great Tweeters for stock locations that are off-axis. I hardly used these as I've only used them for experimenting with different mid and tweeter combinations. This is the tweeter set I decided to go with, I just happen to have this extra set because I love them so much. (Yes, they are that good)
They come with angle mounts and flush mounts that also serve as surface mounts. Also includes unused crossovers (I ran these active).
Also, I know for a fact that they can be crossed over lower than 3khz. I know there are folks who crossed them down to 2.5khz with no problem, and their clean sound remained intact.
I will give a short review is anyone needs it. The complement the MB Quart mids above very nicely.
$60 Shipped
4) Majestic 10-band half-din eq
Don't really know much about this unit. But the eq points are: 30,60,120,250,450,700,1.3k,6k,12kHz
It has 1 pair RCA in and 1 pair RCA out.
Built in 4-ch amplifier, I think it's 25wrmsx4. Would be good for powering some tweets without necessitating another space-consuming amp.
$35 Shipped
I have refs as seller and trader on CACO under same screenname if necessary.
Thanks for looking!
$70 Shipped
$70 Shipped
* 6 Ohm
$60 Shipped
$35 Shipped
Thanks for looking!
