A cheap source for crimp rings!
QtrHorse
It's my first day!
I don't know if this is the right section for this, if it is not can a mod please move it to the correct forum.
I stumbled across this clearance sale at Stella Maris for crimp rings. The cheaper rings are just that, kind of cheap but the slightly more expensive are nice and thick.
The place below is about the cheapest you will find them but the problem is you will be around $21 after shipping and the $15 minimum order if you buy $15 woth of crimp rings. They have two different types on clearance, one is $00.47 each and the other is $00.19 each. You will need the 2/0 ga ring terminals for either Kicker Hyperflex or Knu Kolossus. If you are using welding wire, then the size of the welding wire is the same size of crimp ring you need.
Clearance Items
QtrHorse
It's my first day!
QtrHorse
Tx
snoopdan
