93 ford explorer problem help:(
audiobahnuser18
Alright guy's i need help seeing that my dad is arguing with me and it only happen's sometimes and i just want to make sure my truck is fine. Ok i'll be driving it sometimes and it's fine drives fine. Then sometimes when i drive it sounds like a fckn wind up car from the left rotor i haven't pulled rotor yet it seriously sounds like the bearing bad on a skate or skateboard or something and u can hear it real loud then other times it will not do it. Ugh.....this thing is getting on my nerve's cause other times it doesn't happen. Only happens when it's really cold out also.
more info would be helpful where does the noise seem to be coming from does it do it during acceleration?
only while the car is moving?
from the time you start the car till you turn it off??
we need more info before we can begin to even try an help
I had the same problem with the same vehicle....even the same year vehicle. It was a hub. The hub was replaced, and the problem stopped. Though, without eperiencing YOUR problem, first-hand, I can only guess. It could be a wheel bearing. That would sound very similar to your description. That vehicle tends to hold up well, otherwise. But, the front wheel hub problem is fairly common.
audiobahnuser18
audiobahnuser18
Mi
audiobahnuser18
