93'-98' chrysler,dodge,egale
stangpounder
Wi
Anyone on here drive or drove a 93-97' chrysler--concorde, Dodge--intrepid, or Egale--Vision...all the same basic car. whats the best results you had for box position? what trunk to cab fabs. have you done? (i.e. Trunk porting to cab, removing metal plate between trunk and cab...ect.) what system was the loudest you got?....and also to help me if you did where did you run 0/0 , or 0/1 gage wire through?
thank you very much!!
In almost all trunk cars the best box position is at the back of the trunk (closest to the cabin) with the cone and port firing to the bumper.
Firing into the cabin will only better if you 100% completely seal off the trunk from the cabin, otherwise it will just create reflection waves that are out of phase with the original wave, meaning it won't be as loud and will have a weird response pattern.
Assuming your battery is under the hood, I would say run it through an open grommet in the firewall, and underneath the carpet on whatever side of the vehicle your battery is located, which I believe is the passenger side on most vehicles.
driver side here, and i cant find a gromet big enough...on another note i've seen people firing subs to side of trunk with port firing rear to bumper what with that???
1. Drill your own hole if you can find an open one large enough, make sure to use a grommet.
2. They are dumb, or maybe it just happens to work for their vehicle.
stangpounder
stangpounder
Wi
spoonraker
