900rms @ .5ohm
just get something that does 1000w at 1 ohm. You will be just fine after box rise. Especially since those coild probably read a little higher than the spec sheet says (I know my D2s all read around 2.4)
I have a Kicker XS50 mint like new shape ...this is a clean class AB amp ...not class D (distortion) of today....last of the true American made Kicker...not Chinese new kicker crap.... It was rated at 1 ohm...but will play daily all day long at .5 ....If interested in knowing more about the Kicker XS50 PM me
i see a lot of amp that do 1000rms @ 1ohm but i don't know if they would over heat or go in to protection @.5ohm.
//content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif SAY WHAT
To simplify it....
if the sub is wierd down to .66 when you put it in the subwoofer box the impedence will rise due to a few factors. It always happens. So if it is wierd at .66 then after box rise and once the coils are warm I bet that it will sit over 1ohm. So you can run a amp that does rated power at 1 ohm. An example would be one of my last systems where I had a dual .7 woofer and a amp that did rated power at 2ohms. I wierd the sub @ 1.4 but after rise I was seeing 2.1 at the amp which is right in its sweet spot.
Dre20xl
Dre20xl
Spotyslvania, VA
Hintzyboy
