8k-10k amp
Wired that high the taramps should put out more power than the xfire after rise. I'd look into two 5ks wired at .7 each (strapped at 1.34)
If you know what you're doing and have the electrical I'd say Brazilian, but then again I do not know your experience or level of comfort. I know I am going Brazilian this summer and there are several guys on here that swear by Brazilian for daily rides. But if your electrical can support a big Korean and you have the budget then go for it as they'll most likely last longer.
Could I run the 50k or a 20k amp and just crack the gain open. For the $ that's a good deal and I'm assuming only using half the amps potential would be better for the electrical and amp but could be way off. The only reason I bought 3 separate amps was for resale and if one blew it would be cheap to fix. And yes any other amp I get I'll upgrade electrical also.
A lot of those high output Brazilian amps are high voltage good luck with that. I wouldn't run anything larger than the 8k. If you really want 10k in that $1200 area get 2 5k Koreans and bridge at 1.34ohm. Any 8k or 10k Korean amp is going to need to be wired low to get even close to that power the Brazilian wired to 1.34 you might see 4500w from and can't be wired low.
You do realize the Taramps T50.0KW is a 240VDC amp right??
Get the Taramps HD-8000 and wire to 1.3ohms.
But seeing your signature I wouldn't do **** until you upgrade your electrical. I don't know why you are even trying to run 3 Hifonics 2400s.
Jduane
Jduane
Weymouth, ma
