88.9 mm xmax????????
i have yet to see a sub with 88mm xmax dont believe there is a sub that can do this and be useful.
xmax is 1 way so ur talking 7+" of travel and linear while keeping the coil in the gap.
The magnet slugs look to be 40mm tall, 50mm tops. Top plate is at most 15mm thick (probably less). Back plate is probably not bumped... but lets give it a 5mm bump to be fair.
With a 50mm long coil and 15mm top plate you have 17.5mm of over-hang -- to the bottom of the magnets this leaves 22.5mm on the 40mm stack and 32.5mm on the 50mm stock... at tops with over-hang 27.5mm / 37.5mm one-way mechanical figures.
This geometry yields ~21mm or so linear one-way. So by no stretch of the imagination does this sub have 88.9mm of anything measurable... the surround may handle that p-p but no other part of the sub would.
Before posting I found this :
Earthquake Sound DBXI-15 - Page 3 - Home Theater Forum and Systems - HomeTheaterShack.com
With a 12.7mm x-max figure that drops the coil length down to 35mm or so which would leave 10mm of over-hang and ~45mm of x-mech rearward with a slightly bumped back plate and 50mm stack. So I imagine they are listing distance from coil to back plate x 2 (peak to peak) -- but in this case the coil would have to exit the gap by nearly one inch to reach that level of travel (not happening).
Just a BS spec.
Colossus281
Colossus281
Albuquerque nm
murph
