dynasty36d
do you guys think that using a rockford fosgate 801s amp would be too much power, just enough power, or not enough power, to power 2 12" power acoustic fubr 12"s ?
and do you guys think that 2 he2 12's would sound louder or 2 fubr's off that amp ?
FUBR-12
• 1800 watts power handling
• 200 oz. magnet
• 2” ASV voice coil
• SPL 91 dB
• Sealed box: 1 cu. Ft.
• Ported box: 2.2 cu.. Ft.
• Tuning: 34 Hz
• Port Size: 4”(dia)x12”(length)
• # of ports:1
801s
Amplifier Type: 2-channel
RMS Power: 200W x 2
Bridged RMS Power: 800W x 1
THD at Rated RMS Power: 0.05%
Speaker Level Inputs: Yes
Preamp Outputs: Yes
Built-In Crossovers: HP/LP
Bass Boost: 0-18 dB
Frequency Response: 20-20,000 Hz
Channel Separation: n/a
Signal to Noise Ratio: 100 dB
Fuse Rating: 60 amps
he2
Woofer Size
12"
Woofer Material
Polypropylene
Magnet Size
77.4 oz.
Magnet Type
Ceramic ferrite
Continuous Power Handling
400 watts
Peak Power Handling
800 watts
Impedance
4 ohms
Connection Type
Binding posts
Number of Voice Coils
Dual (2)
Efficiency
86dB
Frame Material
Stamped steel
Surround Material
Foam
FUBR-12
• 200 oz. magnet
• 2” ASV voice coil
• SPL 91 dB
• Tuning: 34 Hz
• # of ports:1
801s
RMS Power: 200W x 2
Preamp Outputs: Yes
Bass Boost: 0-18 dB
he2
Woofer Size
12"
Woofer Material
Polypropylene
Magnet Size
77.4 oz.
Magnet Type
Ceramic ferrite
400 watts
Peak Power Handling
800 watts
Impedance
4 ohms
Connection Type
Binding posts
Dual (2)
Efficiency
86dB
Frame Material
Stamped steel
Surround Material
Foam
