;2747113']The light is always red on mine and it's working perfectly fine. When you say "red red" Do you mean blinking red or you just typed it twice?
Did it stay off? If not' date=' you probably just experienced some clipping. Check your gain on your amp. It's probably too high at whatever volume level you were at. If it did stay off, check the fuses on the amp and make sure they're all intact. Of course a voltmeter will say that there's power going to the amp regardless of whether or not any/all of the fuses on the amp are blown. Unless of course your power wire is effed up.
Hope this helps.[/quote']
ok i thought the light was suppose to be red but I remember seeing green? Anyway I put a cheap roadmaster 6 1/2 to the amp and it was working...blew the speaker
. I put a voltmeter to my massive cw and got nothing? I kinda thought it was blown but I didnt notice anything wrong. Everthing looks to be fine and when I push directly in the middle of my sub I dont hear any scratching...but i do hear scratching if i push off center. What would technically be wrong with the sub? Its under warranty BTW. Time to make another thread...
THANKS for the input.
