8" TC Sounds TC2 / ED e8A.44
ciaonzo
TheContinental
8" Elemental Designs e8A.44 (D4)
Super hard to find these. Phenomenal driver, great used condition. Front side is flawless, back side is dusty and such. Sealed or vented, 400-600w is plenty.
T / S Parameters
Qts : 0.44
Qes : 0.49
Qms : 3.89
Vas : 10.89L
Sd : 0.0190 m^2
XMag : 17.7 mm
XSus : 16.5 mm
XMax : 16.5 mm
MMd : 103.85 g
Re : 1.53 ohm
Fs : 33.38Hz
Bl : 8.32
$175 shipped, CONUS.
UPS
What are the specs on this? I am looking to replace my older dd . how will this fair in a 6th? That's what I'll be putting it in
Posted specs.
Manufacturer's recommendations:
Box Size / Type : O.25cF Sealed
Power Recommendation : 200-350 WRms
Box Size / Type : O.50cF Vented tuned to 30Hz
Power Recommendation : 150-300 WRms
Just selling 1?You said 400 to 600 watts
But manufactor spec says 300 watt?
Will this do about 500 daily?
Just the one driver.
Wouldn't be the first time a manufacturer suggested using less power than what a driver will actually absorb. But is more necessary? Probably not. Depends on your application.
Having 500 on tap will be perfect.
ciaonzo
TheContinental
ciaonzo
WI
ciaonzo
