7515 Worklog (56k DEATH)
Good idea, thanks ill do that when I re do this box.
//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif:eek: I can't believe all these people take the shortuct way with building a box. If you got a router doing the port the way you did it make its look 1000x better.
BTW if you want a EASY carepting job......use a rabbit bit on all 4 sides of the side pieces of the box, wrap a piece of carept around the box (top, front, back, bottom), have the carpet over lap each other and razor blade where both carpets overlap. And then tuck the side pieces into the rabbit cut, and put 2 small pieces on the sides and tuck edges into the rabbit cut.
ArrizX
Scout 800 owner.
ArrizX
Somewhere drinking moutain dew...
audioarsonal
