Sold 7 modded rockford fosgate bd1500
defj
NY
these are modded amps with endcaps.the mod allows for higher voltage and loewer ohms.
DETAILS:
Class bd technology
750 watts RMS x 1 at 4 ohms
1500 watts RMS x 1 at 2 ohms
requires 4-gauge power and ground leads — wiring and hardware not included with amplifier
4-gauge power and ground connectors
150-amp fuse and fuse holder required
selectable 50-250 Hz variable low-pass crossover, 24 dB/octave
MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability.
TOPAZ noise-killing differential inputs eliminate 80% of ground loop noise between the head unit and the amp.
NOMAD advanced protection circuitry monitors temperature, voltage, current and impedance, and provides "intelligent" shut-down protection without limiting system performance.
preamp outputs for easy connection to a second amplifier
wired remote control of Punch Bass (0-18 dB centered at 45 Hz) — gives you fingertip control of your bass impact
POWERsync — a 6-pin mini-DIN connector that allows you to bridge together two separate Rockford Fosgate Class bd amps
subsonic filter removes frequencies below the range of human hearing for increased efficiency
dimensions: 18-1/2"W (13-11/16" without endcaps) x 2-7/16"H x 9-7/8"D
asking $350 each plus shipping,but will lower for multiple amp purchase
you gotta show us some pics of the condition of amp on the forum, so we can have a lil more interest. Use imageshack, works great and no login required. Many people have been scammed on this site, so we need some pics with your name next to it.
haha,finally.hope this pic helps.thats all 16 i have,but only 7 of them are gonna have new homes right now.
defj
defj
NY
defj
