600 @ 8
Any quality amp that does 1200 x 1 @ 4 ohms should do 600 @ 8 ohms.
You just don't see many people running 8 ohm loads, so you usually won't see that in the spec sheet often.
I have a couple of TIPS modded Linear Powers that will do close to that power rating @ 8 ohms. Also, I believe my 25 to Life Punch 150 would also put out close to 600 watts @ 8 ohms mono since its 4 ohm stereo birth sheet rating is 300 and change per channel.
mot many options that will be cost effective really. your best bet is getting a big os amp. maybe if your lucky you can come across another one of those subs to get a 4 ohm load.
x2, running that particular ohm load now would cost alot to get that kind of power. old school is ur best bet imo
Any quality amp that does 1200 x 1 @ 4 ohms should do 600 @ 8 ohms.You just don't see many people running 8 ohm loads, so you usually won't see that in the spec sheet often.
Yeah. I mean, the common order multiplies by 2 each time you divide the resistance by 2.
600 @ 8 = 1200 @ 4 = 2400 @ 2, etc.
At least, that's the pattern I've seen.
There are some amps who give out more or the same at two different resistances. JBL amps are infamous for doing this. I think they have one that does 1200 @ 4, then 1100 @ 2.
I
I was sorta in the same boat with 2 kicker solo-barics and I couldn't find an 8ohm amp at all so I went with old school PPI that does 1400wrms at 4ohms bridged, but luckily I have 2 amps that I can get to a 4ohm load. Is JL and Alpine able to do it with their RIPS technology?
IDSkoT
Resonating Reticular
IDSkoT
Miami, Florida
IDSkoT
