6 channel amps?
Infinity Kappas, 60 watts in in the front and 110 in the back. I don't need that much wattage... the JBLs wattage matches nearly perfect actually as far as power is concerned but if there's a better amp I can get for the same price I'd jump on it.
If you put anything near that kind of power on the rear speakers, they'll be absolutely screaming at you. Run more power to the front than the rear, you'll be glad that you did. Subs? What do you need other than the 4 channels for?
I have 6 total speakers. With the Memphis Belle I figure I'll run the fronts in series and then I can add a sub. I figure even with less wattage, having dash and front door speakers will more than be enough.
fps_dean
da pimp
fps_dean
Williamstown, MA
fps_dean
vegang
vegang
