6.5" separates with most BASS?
E368
The title might be a bit misleading, but...
I am in the market for a pair of high-quality 6.5" separates for the front of my small car.
My goal is to have good SQ with lots of punch and good/low bass since I won't be able to use a sub in this car - 4 front speakers only! I like to listen to it loud with the windows down on deserted back roads...if you get the picture //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Price isn't a major factor but I would like to stay under $1000 for the speaker set.
In a pinch I could probably build custom mounts to fit 7" drivers in the doors but I don't think 8" drivers will fit.
So...can you guys please offer up some qualified suggestions?
Thanks //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Going Active? With a $1000 price limit just on speakers your going to have a sick set of mids. I use Image Dynamics X69s and they absolutely get down without any deadening. I have no issues shaking my rear view mirror with them crossed at 80hz/18dB.
Please tell me you will be powering these speakers with an external amp, right?
Yes! I should have mentioned that //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif I will use a high quality amp, likely in the 75W x 2 range.
Pick up the CDT Audio HD-62AS 6.5" comp set and upgrade the mids to ES 06 Extended Bass Midwoofers.
ES 06 6.7” extended bass mid woofer
Technical specs and contents:
* Frequency response 10Hz-4000Hz
* Power handling:100WRMS (200Watt Pk).
* Impedance 4 Ohm Sensitivity:89dB
* Mounting depth: 2.9”
* Cutout diameter: 5.87”
* Cast frame: OD 6.7”
* Cone: Mix/Kevlar/Fiber glass
* Magnet weight 30 Oz
* Cone surround Buytal rubber
* Impedance: 4Ohm
* Fs: 55Hz
The HD-62AS set is $350 and I don't know how much it would cost to upgrade the woofers, but I can find out if you'd like.
E368
E368
North
Savstyle
