5000w for 130$?
mofos are loud but don't hit deep buy a skar vvx and obsidian 12d2 a brand x XFL 12 or a lanzar opti1232 same price but these get loud like the mofo 12 and hit 10x deeper and just have better sq all around for an amp go with a hifonics brz line u can get for around that 130 mark
It has 4-gauge inputs, and 80 amps of fusing... I'd expect around 1200 watts RMSBeing Boss though, expect that to be at like 5% THD...
umm ok but if you calculate it out at 10 amps of fusing for every 100 watts of power then 80 amps is only 800 watts,so where are you getting 1200 watts from?
My Mofo's get loud and deep. All who are bashing probably never owned any. They are decent for the price. As with any sub its all about clean power and the ENCLOSURE. I'm powering 2 12 in Mofo's on a DAT 2500.1 and they're taking it with ease. Now Boss is a different story.(JUNK)
My initial guesstimate was actually a bit too high after doing the math, but where are you getting 10 amps from every 100 watts of power??
V (voltage) x I (current in Amps) = P (Power in Watts)
So with the engine running, we'll say 14.4 volts of input power, and we're limited to 80 amps of current (continuous).
14.4 x 80 = 1152. This however assumes 100% efficiency, which is impossible. Boss doesn't list the efficiency of the amp, so I'm just assuming the typical Class D efficiency of 80%
So take 1152 x .8 = 921.6 watts
ok but there is a much more accurate way to measure power which i learned from a 30 year car audio veteran
V(ac)/A(ac)= IMP then V(ac) squared/IMP=POWER(WATTS) that is a much more accurate measurement
Foote11
Foote11
Iowa
9515ROB
