4ohm our dual 4ohm
Two svc4 subs wired in parallel will a 2ohm load. You can try aq or sundown amps. Or, a PA amp like mine (cheap way out) either way you are gonna be spending a lot of money for 1200wrms @ 4ohm.
The 5500D I have wouldn't do a full 1200wrms@4ohm. But, its only $250.
5500D is rated 2500@2ohm. More like 2k either amp is a good choice.
wat about JBL GTO14001 at 4ohms it is pushing 1200 watts
Yea, the JBL would be a good choice as well.
I need some clarification however. Do you have 1svc4 or 2?
11cor_k
11cor_k
marshall tx
11cor_k
