Sold 450/4
JLbumpin04gp
Today only.Just bought a ring for the girlfriend,too many bills to pay..asking 350. not sure how much shipping will cost. I have the box,manual and the hex wrench. Lets sell this!
oh,i will have to search for my old post,since thats where my pic with user name is,but the date is old.
congrat on getting a ring!! and i though i would post some specs for you!
Channels 1 and 2:
Rated Power (stereo mode): 150W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V)
Rated Power (bridged mode): 300W RMS x 1 @ 3 ohm-8 ohm (11V-14.5V)
Channels 3 and 4:
Rated Power (stereo mode): 75W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V)
Rated Power (bridged mode): 150W RMS x 1 @ 3 ohm-8 ohm (11V-14.5V)
Peak Power Output 900 watts approx.
Differential-Balanced Input Topology: (2 pairs of inputs)
Channels 1 and 2 Crossover:
Fully-variable (50 Hz-5 KHz), selectable-slope LP or HP (12 or 24 dB per octave)
Channels 3 and 4 Crossover:
THD at Rated Power:
S/N Ratio*: >108.5 dB below rated power
Frequency Response: 5 Hz-30 KHz (+0, -1dB)
Damping Factor: >200 @ 4 ohm per ch./50 Hz
Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
Preamp Output: 2-channel (Pass-through with selectable input sourcing)
Bass EQ: +6 dB (variable boost up to +15 dB with Remote Bass Option)
Infrasonic Filter (Channels 1&2 only): defeatable 24dB/octave at 30 Hz
Speaker output connections: accept up to 8ga. wire
+12V and Ground connections: accept up to 4ga. Wire
Fuse Rating: 60A
Dimensions: 13.4"L x 9.25"W x 2.36"H
RMS Power Range : 150-300 Watts
Number Of Channels: 4
Maximum Power: 900 Watts
Low Frequency response: 5 Hz
High Frequency Response: 30000 Hz
Built In Crossovers: Yes
Channel Separation: Yes
JLbumpin04gp
JLbumpin04gp
Stoughton,WI
JLbumpin04gp
