400AH dual battery setup FL only!
  • 7
Flastrongman
Ft Myers FL
2 C&D 6v 200 amp hour batteries less than 2 months old. Super easy to wire these in series and they rest at 13v, you can safely charge up to 15.9v.
They are extremely heavy so I will not ship them, but willing to meet half way anywhere in FL.
$250 gets both these monsters.
Midwest SPL which is big up here states batteries must be 12v only in adv classes. and I'm pretty sure these would likely fit under Wheelchair/golf car batteries too.
809
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
815
923
You should run all exact matching subwoofers in one singular enclosure and 1 amp or matching amps for the best listening experience for the space...
Flastrongman
Flastrongman
Ft Myers FL
UnderFire
Brendon Jenness
    May 11, 2024
RedRyder18
    May 11, 2024
