4 way vs 3 way
If you're just using coaxials, there's no point in going with anything over a simple 2-way midrange and tweet setup, properly powered off of an external amplifier.
Three and four way coaxials are gimmicks designed to sell, not provide better imaging & frequency response.
For the love of god, read the sticky's: http://forums.caraudio.com/vb/showpost.php?p=767530&postcount=2
In co-axials, a 2-way speaker is a speaker that contains only a midwoofer and a tweeter…..the midwoofer playing the lower frequencies (down to around 80hz or so), the tweeter playing the higher frequencies (around 3khz or 4khz and up). 3-way co-axials typically have a midwoofer, tweeter and "supertweeter", with the supertweeter being designated to handle the very, very high frequencies only. Co-axials can go as high as 5-way (midwoofer, midrange, smaller midrange, tweeter and supertweeter). For all intents and purposes, anything more than 2-way in co-axials is a marketing gimmick. Going with 3-way co-axials or higher usually does not increase performance much, if at all.
Yep. Anything over 2 way is almost always a gimmick. The tiny little "tweeters" you see are parasitic tweeters... they're attached directly to the real tweeter, so they vibrate with it and give off SOME high pitch frequencies, but only a small fraction of what the real tweeter produces. They are in no way a real 3 or 4 or god forbid sometimes a 5-way setup.
3 way component setups are different though.
ben313
ben313
Delawhere?
SSS 18734
Mike Mccabe
