4 speakers and 2 channel amp
  • 2
Clifff150
827
Texas
Hey guys, I have 4 new door speakers that are svc 4 ohm and a 2 channel amp. I want the output of the amp at 4 ohms because it is just over the speakers rated power. Is there any way to do that? I know how to wire the speakers for a 2 ohm load but my amp will give each speakers over double its rms
you wont be able to do all four in that manner with that rating, however i recomend just amplifying the front set, they are the only ones you generally hear anyway, the rear are just fill
It is Opel (Vauxhall) Astra J 2011 model, I change the HU to Kirinavi 10 inch screen. The factory speakers are Infinity and would have come with a...
827
For clarity, why not example 2 ? Example 2 is 2 ohm...my speakers are 4 ohm and amp uses less RMS wattage with the bridged 4 ohm full range...
I don't think it's that easy to answer "for a complete beginner". amp and speakers ratings are those peak or RMS? Are these already installed...
Wiring question....using four 4 ohm speakers and one 2 channel amp capable of 2.ohm load... Using 2 ohm stable 2 channel 4 ohm amp to power four...
Clifff150
Clifff150
Texas
All_Logix
    May 31, 2024
    May 24, 2024
