4 soundstream xxx 18s
maybe try 2 18"s in a wall first, those 2 door blazers are kinda limited in space.. but there are ex. cab S10's with 16cube walls without a blow through so im sure 28+ cf is possible if the wall is RIGHT behind the front seats //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
(you'll probably have to build the box INSIDE the blazer, not removable lol, to get that much air space.)
ok if you have 49 w from side to side then you do not have the space for 4 18. one b/c you need 19" per sub so say 20 each and you have 49 so that leaves 9' for a port. is the with or with out the box if with out then you need to add a min of 5" for the side to beffy. so i would say your best bet is 4 15. hope this helps.
Holy mother of god if that's an 18, that's the biggest motor I've ever seen.
bringtheboom
bringtheboom
ny
dwright27
