4 RCA Output HU: 2 Sub & 4 Ch RCA's?
PIONNER 100DVD
I ran sub on rear and split the front L and R to the L and R sides of the car.
I had 9wire and had it high input but the rca's sound alot cleaner
In a lot of cases the rear HU outputs are switchable rear/sub.
If you set them to sub you'll have a few sub controls from the HU -- sub volume, maybe a crossover.
If you have that option you should run the rear/sub channels to the sub inputs and the front pre-amps would connect to the 4 ch using y cables.
If the HU is NOT switchable - it doesn't make much difference whether you run the rears and sub with y cables or fronts/rears.
In a lot of cases the rear HU outputs are switchable rear/sub.If you set them to sub you'll have a few sub controls from the HU -- sub volume, maybe a crossover.
Rears are switchable. OP, looks like you already have it wired correctly. If you haven't already, switch rear output to sub.
KMahl
KMahl
Colorado
fly_marlin
