4 hc800s?
2 18 Fis on a ap30001d
should sound pretty good. think of it this way on the batteries. if you run the stock under the hood, it can concentrate on starting your call, lights, etc while the 4 in the rear concentrate on the system itself. removing that stock will put extra pressure on the kinetiks which will of course, result in lower voltage on your amp which equals less power and more abuse to the amp. good luck with everything.
Bovine scatology
If they are not isolated how do the 800's know not to start the car?
Isolating is primarily to keep your batteries from discharging when the car is off. If you have 2 batteries with different charges, the one with the lesser charge will drain the other and so on. otherwise the more batteries doing any one particular thing, the better.
And yes, as you hinted at, it will also let you run the entire audio battery out without killing the car starting battery.
well you have 4 batteries hat are basically identical the (charge and discharge the same), the stock battery is more than likely not close to the 800's, yu can run into issues with mismatchig batteries. it has been discussed many times, I am sure a simple search will enlighten you with more detail. is short by mixing you put a lot if strain on your entire electrical system, and the longevity can be compromised. just my $0.02
first part, not really, second part correct
C_james7
C_james7
Bellevue, OHio
C_james7
Mike Mccabe
