4 channel audio set up
rambow70
Front size: 6 1/2.... 3" depth
Rear size: 6x9....... 2" depth
Tweeters 3.25" (not necessary)
Car is a 2g eclipse gst with the infinity stock amp which I plan to replace with a better 4 channel.
My budget is around $850 all said and done. I want new rear, door, amp, and head unit. Tweeters are an option or if coaxial is better for my money I can do that. For the amp I want 50watt rms x4 going to each speaker.
I am not going to power but for really good clarity and 3D sound (a bit of bass without a sub, not flat, no distortion)
Could anyone whip up some set ups I can look into? Any help would be appreciated! I still do not understand car audio very well.
Ok, this is the set up I came up with. The rms from the speakers and amp line up perfect. The rears take a little more juice but it shouldn't matter, should it? I won't be blasting anything but I do not want to under power anything and I want a good brand. So the fronts need 60watt rms -> 120 from the amp, rears need 100watt rms -> 200watt from the amp. The amp buts out 160watts x4 @ 2 ohms which the speakers are also 2 ohms. So the front two will get plenty of power but will the rear suffer?
Front
JBL GTO628 Grand Touring GTO 6.5" / 6.75" Car Speakers
Rear
JBL GTO938 Grand Touring GTO 6" x 9" Car Speakers
Amp
MB Quart RA640.4 Reference Series 640W 4-Channel Amplifier
Head unit
Pioneer DEH-X4700BT Bluetooth CD/AM/FM Stereo w/ Pandora Support
Also budget change. $500 MAX, I do not have 850 to spend on audio haha!
rambow70
rambow70
United States
rambow70
