4-channel Amplifier Installation
Savackz
GA
I have a MTX RT4240 amplifier and I want to bridge it to the B2 Audio ES6.1 components I have for the front stage. Mainly, I am wondering:
1) How many RCA cables am I going to need? and,
2) How do I wire the tweeters with the crossover? and,
3) Am I going to need any y-splitters?
Thanks in advance!
1) Just a pair. The amp has 2/4 ch input select
2) Are you asking about the 0, -3, -6 connections? It's completely personal preference. My tweeter x/o has a +3/0/-3 and I use the -3 setting and still run my hu "hi" setting at its neutral setting. Unless you KNOW you don't like a lot of tweeter you should probably stick with the 0 or -3, -6 seems pretty severe. You can always fine tune with the HU.
3) no
1) Just a pair. The amp has 2/4 ch input select2) Are you asking about the 0, -3, -6 connections? It's completely personal preference. My tweeter x/o has a +3/0/-3 and I use the -3 setting and still run my hu "hi" setting at its neutral setting. Unless you KNOW you don't like a lot of tweeter you should probably stick with the 0 or -3, -6 seems pretty severe. You can always fine tune with the HU.
3) no
Thank you! And I am wondering, do I just hook up my amp to the crossover and then speaker wire from the crossover straight to the connections from the tweeter.
Savackz
Savackz
GA
n2audio
