4 3004spl Premiers
i used it and it seemed like the subs were like 2758 watts peak.
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
But The Amp Could Go 4000 At 18v. It Should Be Ok. Or Should I Use Two Amps LIKE 1800 RMS EACH. Need To Know Cuz Im Buying The Stuff Soon
thats my point...
most likely, you'll be running at around 12-14 volts...MA is known to rate their amps at 17+ volts...
i don't know your amp super well so thats why i said hopefully it can push out at least 3000 rms on a regular basis...if so then you should be good...
how much r u getting that amp for? how much do u want to spend on the amps?
def keep the tsw's cus for the money, their pretty much unbeatable...
suburban_man
suburban_man
MA
bigbangtheory
