(4) 15' CVX will 2 3200w hifi Colossus do the job?
Edd_Hardy
(3 question) im going to do the big 3 what dry cell battery will be good? but i need to know is the C.LTD 3200w going to put my subs in a headlock. are they really rated what they say they are? i did 3200w + 3200w = 6400w / 4 = 1600 so is each sub going to get 1600 watts pushed to them? im new at this.
What amp are you using exactly?
Nice avatar .... Can I borrow some cash?
---------- Post added at 12:27 PM ---------- Previous post was at 12:27 PM ----------
And make sure u get some capicitors gunna need like 6 for that many watts dude !
lol you didnt awnser my questions....
You need a new alt, two batts, lots of 0 gauge, and then the fun begins ... As far as batteries there's some cheap for sale on here now ... And imop if u wanna push the 4 cvxs hard ... Tell me what ohm they are and ill recomend one good amp instead of two meh ones ... Now about the cash timothykohles@gmail.com feel free to send a couple hundred //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
---------- Post added at 12:38 PM ---------- Previous post was at 12:37 PM ----------
Lulz, oh man..
Just keepin it realz mane !
mine is 4ohm and i wish i just had money to give away it would be nice. but is the Colossus good. because i dnt want to by an very expensive amp thats why i was just going to roll with 2 colossus.
Lol, this.. OP your gonna have to fork out a lot more money on the elctrical system of your car as mentioned above before you can hook those amps up.. You'll smoke both of them
Those are power hungry amps, as I said above, no electrical and you can kiss them goodbye
o believe im going to get extra battery, HP Alternator, Cap and 0 gauge wires. and im not going to be having my bass turned all the way up. this is going to be for sunday drives in my custom car not all day everyday use. i listen to Screwed and Chopped music. not hyped up Rock music that bass through the whole song. mine is going to be Knock and Slap
First things first ... I was joking about a cap... They are worthless so no caps... Next if u have two on a collosus ... Then the first thing I'd consider is a new box ... For the 2 ... And do your electric beef the voltage on ur one amp and get rated out of it ... Then I'm guessing you'll be very happy with the results .. If ur dead set on four 15s .. Then start saving...
DO NOT GET A CAP.....LOL.... just grab a few batts, a bigger alt and do at a few runs of wire. For example, for each power wire you run front to back, run a ground from front to back. Trust me it will help
Honestly........ You may only need 1 3200watt for 4 of those if you get them in the right box
---------- Post added at 02:38 PM ---------- Previous post was at 02:37 PM ----------
o yes im getting a ported custom 4 15 box built in might get a 250 alt (if i need it) what amp of a battery will i need?
Batteries depends on what you want to spend
Edd_Hardy
Edd_Hardy
Houston, TX
d77543020
