4 10" SE's or New XXX 12"?
DoubleR
I have 20X50X13.5 to work with 13.5" would be where the sub would sit so im not sure if the 12" would fit so which of these two setups would u go with? I want to go ported with both setups. If I get the XXX it would be run off a Lanzar Optidrive and if I get the se's they would be off an amp that does 2500W @ 2 ohms. Also any help with the size of the boxes would be greatly appreciated like I said both ported around 33Hz.
XXX for the SQL and the wow factor. I'd personally get the 15" whenever it comes out, but if you can't wait, get the 12.
he said he only has 13.5in. to work with on the side the subs will be mounted on....15's are out
also remember the xxx is slightly oversized for a 12, but it should still fit fine
just slightly eh //content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif that thing is MASSIVE lol
DoubleR
DoubleR
Brighton,CO
Shinobi
