Sold 3Sixty.2 and Alumapro CAP 15
Safe_Cracker
Ok next up on the holiday trip fund block is a great condition 3Sixty.2, I never had the original remote/manual so I will inlcude a NEW kicker amp remote which works perfectly and a disk with the 3Sixty.ISO burned for you and I will download the manual and print it if you wish, or add it in .PDF format on another disk. One of the mounting feet has a hairline crack barely visible but I will mention it because I am honest, $250 shipped. I also have an Alumapro CAP 15. This is there 15 Farad version. I have nothing with it only one of the power relays, no box, no manual (downloadable), and no hardware. It is in great condition and has all the setscrews for it. Paid over $300 for it, I want $110 shipped . These prices are for the lower 48 only and if you want it shipped anywhere else it will cost you. I use USPS priority, insured only. Thanks for looking...Polo..
when u said u only have one power relay for the cap .... how many is there suppose to be? also do you know if the cap works?
thanks
Ya, the cap works it is solid state. It charged up and holds a capacitive charge. There is two relays, one is a smaller 12V low amperage ignition source relay like on a car alarm, the second is a high amperage battery disconnect relay, separates the battery from the cap to keep it from draining the starting battery.
Here is the diagram on PDF >http://www.alumapro.com/docs/cap15wiring.pdf
Move this up ^^^^^
Hello/
I wish I could do the Cap right now/:( .That would take care of the system going into the Stang.I have 4/StreetWires 1/Farad Caps Brand New but wanted to get something like this.
I had the Stickers removed from them for a Custom effect...Not looking for trades are you? Jus' asking.The best w/your sale.
Regards/
Raymond
I'm sure it would. All it needs to do is switch the power relay on when the ignition turns on doesn't take much. The one that comes with it is one like from a car alarm, pretty small. Polo.
Safe_Cracker
Safe_Cracker
Chicago, IL
Safe_Cracker
