3sixty.1
Beerdrnkr
I believe the 3sixty.1 has 6 channels front, rear, sub, and then a center channel right? I'm running some rainbow Germs which I want to put in kicks and some dayton rs180-4's that I want to put in the doors, could I use the center channel to adjust the daytons or would I just use the amp? I've also asked this a few times with no real reply, but for my setup would the LC8 w/ an EQX that I currently have be the best option or should I sell the EQX and get a 3sixty.1?
This is my setup: 1 TC Sounds OEM 10 w/ PR, Germs, dayton rs180-4's, focal coax rear fill, mtx thunder 1501d modded, mtx thunder 502 2ch. for germs, mtx thunder 564 4ch. for daytons and rear fill.
I would go with the 3sixty. You need a palm pilot to program it so keep tha tin mind. It corrects the equalization problem with your factory hu that cuts off the bass as the volume goes up. I am not sure if the audiocontrol does that. The 3sixty is just a little tricky to program but I called rockford fosgate today for something else and tech support is nice so I am sure they will help you.
But what car do you drive cause I think for the price of the 3sixty you could get a real nice hu that would eliminate the need for it.
Beerdrnkr
Beerdrnkr
San Diego
Beerdrnkr
