3ohm speakers and 4ohm amp
  • 4
KMS
SoCal
Can this cause any problems? Right now I have component set in the front stage and coaxials in the rear. I believe all 4 speakers and components are 3ohms.
I have my stock tweeters from the car spliced into the same wires that connects to the coaxial.
Anyway I'll soon be installing an amp that will be running at 4 ohms. Will the 30hm speaker cause damage to the amp or anything? Right now I have everything running off of the headunit. //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
you'll be alright.my factory speakers are 2 ohm,every headunit i've had in there has worked fine.
If anything,you might get alittle more power to them with the amp.
You should be safe, it may send the amp into protection at loud volumes. But I doubt it //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Thanks for all the replies. Much appreciated.//content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
I would not opt for the inexpensive Focal's (and I've used/use currently - their products extensively in both car and HT applications) and while a...
The Deaf bonce unit are not mdbass, they are midrange drivers. They will play pretty loud from 150 up. I don't support the company right now as...
214
You are clipping at the HU, and as stated.. will eventually damage the HU if continued. sounds like you need a little more power as stated. A 2 ch...
112
38
KMS
KMS
SoCal
KMS
    May 18, 2024
    May 18, 2024
