32" of round port enough for 3.5 cf?
Looking at building an enclosure for a single cheap 15" and im figuring a good size would be 32" of port via 2 4" abs tubes 15" long. Box is around 3.5 net. Whats everyone think? Ive used round ports a couple times and they worked great, but im wondering if like 10" of port per cube will be fine for round ports?
lol, maybe for a 4" aero but that's the only size that would work for.
The proper formula for AREA, not Volume is Radius^2 x Pi(3.14)
Volume is- Radius^2 x Pi(3.14) x Length
Lulz good catch, lazy mental moment for me. Just did it in my head and had the 4" stuck where 2"x2" shoulda been. Gracias.
Hmm, I've always been taught the volume of a cylinder is πr^2h, So in this case his 4" tube would be V=3.14(2^2)14=175.9?
Why is this so incorrect?
When port area is discussed, the main factor is area of the opening. Too small=noise. Too big=a variety of issues.
When tuning is discussed, port length is then also included.
You need sufficient port AREA for a certain enclosure. Usually 12-16in per cube for slot port. Slightly less can be done for flared aeros.
Then once you have proper port area, you adjust the length to achieve the desired tuning.
Okay so isn't the volume of a cylinder and area the same thing?
2x2x3.14 x 15" for the ports gives me pretty much 32" of port area, which is about 10 per cube. Ive heard of people using less, these arent flared though i assume that makes a diff?
If i do one 6" port i can get almost 36" of port area, think i should go with one 6" instead?
I Like Waffle
North Carolina
I Like Waffle
