I have a 3000w amp. @ 2 ohms and 2.66ohms it gives me almost the same power (a bit less).. and about 6 cu.ft. (considering woofer displacement wood port ...)
Yes, 2 15 probably will have a little more cone area (DD doesn't show "sd" parameter) but considering that 2500 series has a 80mm suspension and 1500 a 55mm suspension I think it will be almost the same.
3 12's (1500) have 360oz of magnet weight (more magnetic field ?)and can handle 1500rms of power. 2 15's (2500) have 320oz of magnet weight but can handle 1500rms as well. I can't compare another parameters because I onle have the 2500's FS.. but not QTS, VAS, etc...
I don't know if I'm thinking right... that's why I asked you.
