Sold 3 Sundown saz-2000s $450 shipped
roarzorz
lulzorz
I have three Sundown Audio SAZ-2000Ds for sale. They're are in MINT brand new condition. Price is $450 shipped each.
Rated power output
----RMS power, 2 ohm linkable/dual mono
4000W x 1CH
----RMS power, 1 ohm mono
2000W x 1CH
----RMS power, 2 ohm mono 100W x 1CH
----RMS power, 4 ohm mono
500W x 1CH
Signal to Noise Ratio >90dB
Low pass frequency crossover 35Hz~300Hz
Subsonic filter 10Hz~60Hz
Bass boost @ 45Hz 0~6dB
Phase shift control 0~180 degree
Frequency response 10Hz~350Hz (+/- 1dB)
T.H.D @ 4 ohm
Efficiency @ 4 ohm 86%
Fuse rating 200A (external type fuse)
Input Sensitivity 200mV to 6V (+/- 5%)
Dimensions 252(W) x 58(H) x 434(L)mm
SPECIFICATIONS:
* Digital Class-D Linkable Mono Block Amplifier
* Double Sided Through Hole Epoxy PCB
* 1 Ohm Stability
* Daisy-Chain Through Output RCA
* Efficiency : 86% @ 4 ohm, at 100Hz
* 24dB/Oct Variable Crossover
* Multi-Way Protection Circuitry
* (Thermal/Over Current/Speaker Short/Speaker DC Protection)
* RCA Line Input and Master Output
* 24dB Octave Crossover Slope
* 24dB Octave Variable Subsonic Crossover Slope
* Variable Bass Boost
* Variable Low Pass Filter
* Variable Phase Shift
* Zero(0) Gauge Power Supply Connectors
* Tested Voltage & THD : 14.4V & Less than 1% THD
* Operating Voltage : DC 10V~18V
* Wired Remote Controller
* MSRP $899 USD
roarzorz
lulzorz
roarzorz
vag
roarzorz
