lolWhat do you think i Should tune to. I want it to slam the spl and get great sq
I don't know the exact specs of those subs, but I don't think you will have to if you don't want to. Just make sure to brace the port if you making one go across the bottom of the enclosure. It will be rather long and will likely flex a bit if you don't.The design that i am hoping to achieve is all three subs firing up and one common slot port at the bottom firing to the rear of the suv. Hoping to achieve my first kerf design. I was curious to know whether or not i should give each sub its own enclosure.
