3 CVR's and 1 btl
All a wall is - is a huge box that is sealed off.
Wall would be you makinga huge box, from ceiling to floor, from side to side, with the two woofers facing forwards and (generally) a port on the side of the woofers also forward firing. You then seal it off from the rest of the vehicle(in order to no longer allow air past the wall into the extra space behind it/around it)
Stop trying to run the strongest 1 sub setup with all that power. You will almost every time be impressed more with cone area vs. a 1 sub setup. That zx2500.1 on 3 Se15's, 3 SDC2.5 15's, or 4 RF P3 15's should beat him. To your ear more subs will sound more impressive. If you install it right, 2 HDC315's should beat him, but 4 SDC2.5 would sound louder with that amp.
comp vrs are surprisingly loud. They sound like midgets getting ***** in a garbage can tho.
//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif funny post of the day
how big is your box and whats it tuned too? is your btl fully loaded or stock? also is it sub up/port rear, or sub/port rear?
BassFreq
BassFreq
Vancouver, WA
na_rsx
